Posts dealing with Reverse engineering of CGO3+ and UART were moved to this new thread Reverse engineering CGO3+ UART
no you are good i made a lot of changes (too happy coz now i can change anything i like) so not surprised actually, i should to leave default parameters from you @1stI don't have this effect with the landing gears. Did you have changed the channel number for the gears?
@05:00 that descend doing by RTL auto land, but after that i try to take control for landing but the symtoms still remains it deploy after certain meteres above and back to retract under it even the fligh mode are on stab & poshold mode no changesTry to up LDG manually (by remote) and test the automation.
I have no need for this.A GPS module added will cover all the rest of possible functionality .
Added a description here:
Yes, exactly.So if I understand this correctly, the ST16 connects to the CGO3+ via wifi like normal. Then the ESP32 reads the serial from the CGO3+, converts that serial data into pan and tilt commands, and feeds them back to the CGO3+ over serial?
Yes, exactly.
Another possibility is to read the data from SR24 and create the same control messages and send it to the gimbal of the CGO3+ or to a C23/E90 camera (and possibly all other newer Yuneec cameras). This is also tested and can be used for other RCs that do not have Dual Band Control Redundancy.
A use case would be to equip a Q500 with CGO3+ and ST12. With the knob at the ST12 you could turn around the camera (but have the landing gears on video ;-).
