Problem with ST 16
Looks exactly like a camera where the side slider is in the full down position. If so the camera is doing what it is being commanded to do...
Place the slider in the middle position and calibrate the gimbal again. On second thought, place all the controls in the center position, calibrate the entire system using the hidden menu calibration sequence, assure that all controls are centered at the beginning and end of the calibration, then perform a gimbal calibration agin with the slider starting and ending the process in the center position.
Had a calibration been performed with controls off of center those controls would redefine those off center calibrations as a new center.
As I have done precisely that I have also experienced a downward facing camera at the center slider position and resolved it by performing new calibrations correctly.
Ora ho un altro problema, il carrello non si ritrae :(
Al comando solo uno sembra rientrare ma l'altro non si muove
marc13690
