probleme de visualisation de film
bonsoir a tous voici mon probleme lorsque je fais un film avec mon q 5004k au moment de la visualisation celui ci fais des vagues comment resoudre se probleme merci serge
when I make a movie with my q 5004k at the time of viewing this one makes waves how to solve problem thank you serge
If I understand you right (and not sure I do !), the waves you are referring might be what is called 'jello', and that usually happens when something is wrong with (one or more of) the rubber dampers on which the camera hangs. Check them all carefully to make sure they are bearing the weight of the camera platform evenly, and that none have come loose at either end.
fotozone
