Q500 camera
I tried a search first before a ask what may be a stupid question. When I power my q500 up, the camera gimbal motor can be heard running.. I never remember hearing that. Thanks ahead of time
This is probably the fan to cool down the camera (processor & electronics).
You can switch off the cooler by placing a file "temperature" (w/o extension) to the root of the SD-card. file can be empty, only the file name is important. This makes only sense if you use the internal microfone of the camera.
In autumn/winter no problem to use it - in summer, it is your responsibility to go on without cooling.
Thank you. It’s funny that I never heard that running constantly, but since I bought my H I haven’t used the Q500 as much
Good to know. I will pay closer attention on the H. I thought the fan came on when needed via a sensor. Thanks again
It might be only a coincidence but I noticed that the fan of my CGO3 is a lot louder than the fan of my three CGO3+. Sadly I do not have another CGO3 to compare. The CGO3 is also older so it might be the reason.
I’ll have to listen again more carefully to it
Thanks for the info
TroyBoy
