Question of Gimbal set to Global position
If I want to fly left to right and set the camera/Gimbal to Global position so that it is looking at me, will the camera continue to look at me even as it flies farther away to my right? Or should I have the Gimbal set to the middle position? It seems that as the aircraft flies away to my right it no longer remains pointed at me?
Yes, I understand that. Just trying to figure out exactly what Global mode does for the camera?
The following is an excerpt from @ogrench's updated "Typhoon H Plus Manual". I don't use these features, but the wording seems to indicate "Global" will not produce the result you seek.
I would also recommend reviewing pages 38 and 39 of the manual for a description of the various task modes, and which modes might serve your purpose.
Reactions: Mike Irish
Global mode locks the gimbal's azimuth angle. The H can yaw around while the camera aims one direction.
Understand that. However if I continue to fly straight ahead, left to right, is the Camera supposed to keep looking back at me? Or will it fly out of range?
apalomba
