Running all three apps on one controller
As a die hard Yuneec fan, I was thinking of trying something with one of my extra st16s controllers.
The Typhoon H, H Plus, and Q500 all run apps on an Android based system. Has anyone tried to install all three apps on one controller?
I am just trying to eliminate the need to carry two extra controllers with me, when on the road.
I want to be able to view the camera feeds, including the MK58, with the ST16s.
Is this possible? Has anyone tried it?
The Q500 will fly on the original ST16 firmware. The screen image qualitly will range from unusable to almost perfect, depending on how current the firmware is on a CGo3. No idea how it will look with an MK58, but it does not sound good.
I believe @slw74 may know more about running the Hplus on an ST16.
I have a ST16 (not S) that has DataPilot for H520, FlightMode2 for H Plus and FlightMode for Typhoon H. DataPilot (Default start-up) and FlightMode2 have an icon to start it in Tab mode, H flightmode not. To start it you need to Settings > Home > select the H icon FlightMode and tap on the home button.
The home setting is lost if the ST16 was off. It starts always in H520 mode.
It is possible to prepare a home app with choice what to start further.
An Android home app launcher is
a user interface that replaces your device's default home screen, allowing for extensive customization of its appearance and functionality. You can change how your apps are organized, customize icons and widgets, and even modify animations and transitions. Popular launchers include Nova Launcher, Smart Launcher 6, and Microsoft Launcher.
Just to confirm what I believe has been discussed before...
The various apps only work with the craft it was made for, right? I can't just stick Datapilot on and use it with the HPlus, can I?
I have a personal mapping project that it would be helpful for... But I can fly manually if I have to. I'm the customer so it doesn't have to be perfect, and with Google maps being about 1 metre per pixel, anything is better than that 🤣
I’m not sure if @Tuna is still supporting his software, but this thread covers the H+ version using DataPilot to plan a mission and converting it to a CCC.
GiftNexa Jaipur
