Sample of my Typhoon footage
Hi All, just a short clip of some of the work I have being doing.
All shot on RAW.
Shame my gimbal has a slight tilt, and yes I have calibrated a million times.
Love it!
My gimbal did the same thing. I thought it was screwed and then I figured it out, at least for mine. Take a close look at your dampeners. I had one that was not seated all the way. Ever since I pushed it in, no problem. It was only out a tiny little bit, you couldn't even really see it, but it was enough.
I hope this is the solution for yours as well.
Murray
All shot on RAW.
Wow it's so beautiful, I like the shots!
All shot on RAW.
My gimbal also had a tilt and I calibrated many times, but when I took a closer look the rubber grommets were incorrectly attached. 3 of the four were not attached correctly. It was a yazoo to get them corrected about an hour. Needle nose and very tiny screw driver. went out today and happiness.
Reactions: TheGryme
Oh, make sure you take the gimbal off the aircraft to work on it.
Really nice
Wish to do footage like that , im really good with PS but video program , humm just starting..
All shot on RAW.
Hi,
Beautiful footage!!!!!
You probably have already answered this, but I'm going to ask it again; What program are you using to edit and stitch you beautiful Clips together?
Thanks in advance!
Ray (TheGryme)
Hi,
Thanks in advance!
Ray (TheGryme)
It is a system made by a company called Snell Advanced Media or SAM. I is called a Quantel Rio.
Skowi
