ST-16 screen is blank.
When I came back from flying today, I plugged in to recharge (it was at 75%). An hour later, I turned it on to check the charge; thin vertical lines started going across the screen. I turned it off, but now it won't turn on--the blue light comes on and it makes some beeping sounds, but the screen remains blank.
I had that happen when I had the USB plugged in and I removed the battery to charge externally.
Unplug the USB, remove the battery. Turn the ST on and off. Reconnect the battery and turn it on. It may take a few power cycles before it works correctly.
I tried that (except for turning it on and off with the battery removed); called Yuneec and they told me to send it in for repair. Thanks for responding.
thiago jonas
