Here are some pictures. I cannot connect to ANYTHING Wifi, not even my home Internet. I used to be able to do that at least. You can see that the CG04-92CA80 shows "saved, secured with WPA2" and that's all there is there. Can't connect to it. Both Frontier ( my Internet ) and the C100E3 will connect and then disconnect and show disabled.
I can control the camera (like zoom) but still not the Gimbal. I can hear drone "beep beep" when I move the controls, but nothing happens. I cannot see, nor bind to the CG04 camera, only to the mysterious C100E3.
You can also see that I have set the camera to the CG04.
The switch settings shown should allow me to tilt and pan the camera, but nooooo.
OK. Now I'm confused.
1.) The WIFI screen shows the camera is broadcasting WIFI.
2.) The screenshot shows the controller is receiving video from the camera that would not be there if the camera was not bound to the controller. (Unless it is seeing "Yuneec_C100E3" instead of the CGo4))
3.) The screenshot also shows telemetry that would not be there if the drone was not bound to the controller.
So the Drone and camera are bound.
Lets move on to figure out the rest of the story.
Please understand I don't have an H920.
1.) What exactly is a "Yuneec_C100E3"? At one point you mentioned it as a hand held controller. Another you mentioned it as a "mystery".
a.) Does the "Yuneec_C100E3" show up if the drone is not turned on?
b.) Does the "Yuneec_C100E3" show up if the drone is turned on but the camera is not mounted?
c.) Have you told the WIFI settings to "Forget" the "Yuneec_C100E3"?
d.) If the "Yuneec_C100E3" is a hand held controller (or camera, or anything else you can identify) have you ensured it is not turned on?
2.) When you double tap the volts Icon on the main screen, a final output display will appear. Rotate the Pan knob (K1) back and forth. Move the tilt slider(K2) up and down. What channels move for each, and what is the max/min value for each of those channels? Please do not mistake the Hardware Monitor for the final output display. They are not the same thing and they are not looking at the same thing. You need to open the actual final output display by double tapping the volts icon.
3.) I notice from the screenshot you have "Advance Mode" turned on. That creates concerns of issues in Channel settings. Have you ever gone into Channel Settings? Even if you did not change anything.
