ST16 discharges the battery (ST16 vybíjí baterii)
Baterie se vybíjí v ST16. Baterie je dobrá. ST16 je vypnutá a vybije baterii. Kde hledat závadu?
The battery's discharging in ST16. The battery's good. ST16 is off and drains the battery. Where to find the fault?
This could be something build-in charger chip status. I know this also from other Android devices. Remove the battery completely (pull EC2 connector), wait 10min or so and bring it back. Check if the effects disappered. Maybe it helps.
You have to set all values (language, timezone, time again).
Je to pořád stejné. Pokud vložím baterii, tak se vybije za 2 dny. Dělal jsem to několikrát. Myslel jsem, že mám vadnou baterii. Zkusil jsem baterii v jiné ST16 a také i vyjmutou z ST16 a baterie byla dobrá (v pořádku).
Máte schéma, kde je závada ( schéma poruchy)? Mohu měřit a najít závadu ( poruchu, vadu). Mám 2 ST16 a porucha je jen u jedné. Porovnal jsem to.
It's still the same. If I put the battery in, it dies in 2 days. I've done it several times. I thought I had a faulty battery. I tried the battery in another ST16 and also removed from the ST16 and the battery was good (fine).
Do you have a schematic of where the fault is ( fault diagram)? I can measure and find the fault ( failure, defect). I have 2 ST16 and the fault is only in one. I compared.
Ano, to dělám. Já ale potřebuji schéma nebo poradit kde vadu (závadu, problém) opravit.
Yes, I do. But I need a diagram or advice on where to fix the fault (glitch, problem)
Hmm, not good. I think nobody but Yuneec has a schematic. You can try to add a ampere meter and unplug/plug the differnt modules inside the ST16.
Another possibility is a factory reset of the ST16 if this is caused by Android SW.
ahoi HE
I had the same problem. Even bought a new battery but same result. Batteries discharged instead of charging. Problem was resolved by cleaning the micro usb plug and socket with "Corrosion X" (tm) electrical contact cleaner and changing usb cables.
Není stejný problém. Moje ST16 nabíjí. Když je vypnuto 2-3 dny tak se baterie vybije.
Pokud se vám nepodaří najít problém na desce, budete muset vyměnit celou desku řízení letu. Pokud si koupíte novou desku, bude to vyžadovat pájení. Níže uvedený odkaz vede na zdroj použitých desek s již provedeným pájením. Možná najdete podobný zdroj blíže vašemu okolí?
If you cannot locate the problem on the board, you will need to change out the entire flight control board. There will be some soldering involved if you buy a new board. The link below leads to a source of used boards with the soldering already in place. Perhaps you can find a similar source closer to your area?
Pokud se vám nepodaří najít problém na desce, budete muset vyměnit celou desku řízení letu. Pokud si koupíte novou desku, bude to vyžadovat pájení. Níže uvedený odkaz vede na zdroj použitých desek s již prokázaným pájením. Možná najdete podobný zdroj blíže vašemu okolí?
Pokud nemůžete problém lokalizovat na palubu, budete muset změnit celou desku řízení letu. Pokud si koupíte novou desku, dojde k určitému pájení. Níže uvedený odkaz vede ke zdrojům použitých desek s již zapájeným pájením. Možná najdete podobný zdroj blíže vaší oblasti?
[URL unfurl = "true"] https://yuneecskins.com/all-products/ols/products/st16-flight-control-board [/URL]
Další řešení je vše zahodit a koupit jiný dron. Typhon 2x havaroval pro poškození jedné vrtule. Nepřistál na 5 motorů a zlomil nohy. Zahodit Typhon a koupit jiný stroj, jiný system Tisíc problémů. Typhon po každém malém problému havaruje a škoda větší než koupit jiný systém. A chodit s batohem na zádech? Konec s Typhonem.
Another solution is to drop everything and buy another drone. The typhon crashed twice due to damage to one propeller. He did not land on 5 engines and broke his legs. Drop the Typhon and buy another machine, another system A thousand problems. The typhon crashes after every small problem and the damage is greater than buying another system. And walk with a backpack on your back? End with Typhon.
Pokud nemůžete problém lokalizovat na palubě, budete muset vyměnit celou desku řízení letu. Pokud si koupíte novou desku, dojde k určitému pájení. Níže uvedený odkaz vede ke zdroji použitých desek s již zapájeným pájením. Možná najdete podobný zdroj blíže vaší oblasti?
Děkuji za radu. Jak vidíš, samé problémy a házení peněz (dolarů). Proč za tyto peníze nekoupit raději jiný systém.
Thank you for the advice. As you can see, the very problems and throwing money (dollars). Why not buy another system for this money.
Sierrarhodesss
