ST16 from meters to feet
Power up your ST16. Press System Settings at the bottom of the screen. Click "OK" then click Other Settings. That window will give you the choice of displaying data in feet or meters under the setting Measurement Unit. It's defaulted to meters. You want to select Imperial, which will display your data in feet by default once selected. Good luck.
Reactions: BobW55
Ronboy
