ST16 wifi board parts.
I got working st16 controller with broken wifi.
Bought it and just realized that somebody use soldering machine with wifi module.
I took a picture of my wifi module.
There is a missing resistor? - litlle one on the right side. Bigger part in the same circle looks like it is a little bit burned.
By photos i found on the internet now i can tell that the "thing" on the left side is not from this module. Original part was 8pins, here i have something with 6pins and it is soldered wrong.
Can anybody tell me what parts are this? Where can i buy it? I know i can buy new wifi module but first i want to try fix this one.
Sorry for my english language.
Thanks in advance.
Thanks in advance.
Where are you from?
I have a lot of wifi boards in stock
The missing part is a ceramic condensator. It will suppress unwanted frequencies on power rails. The yellow is electrolyte condesator for lower frequencies, the missing is to suppress higher frequencies. I don't know what size it is but this is not really critical. Usually it is 47myF for the yellow and 100nF for the ceramic. If this will not fit mechanical, try smaller values.
The chip seems to be a 5V to 3.3V voltage converter. I think someone tried another one compared to the original chip.
Reactions: Typhon H480
Where are you from?
Poland. What is the price of ST16 wifi board? I don't know if it's worth it to fixwith buying whole new part. I saw used ST16 I have good condition for about 100$here.
I have ST16+ too, but it will be great if I could resolder missing parts in ST16 wifi board and check if it works.
Many thanks for you!
I will look now for those over internet.
Maybe somebody got full names of those parts?
It's better to buy the ST16 for 100,= because the wifi board including shipment is about the same price.
Reactions: Douggieboy
I have not opened my ST16 for now because the most SMD parts have no or not really helpful impints. So I only speculate.
The yellow capacitor:
Link to datasheet: https://asset.conrad.com/media10/ad...tantal-kondensator-smd-100-f-10-v-10-1-st.pdf
The missing capacitor:
Datasheet: %product-title% kaufen
The datasheets may help with packaging and dimensions.
The step-down-converter 3.3V may be a LT3685 (it has 10 pins on my pictures). The circuit may look similar to this:
But it is worth to try if the existing circuit do provide 3.3V.
dobrze się bawić
pozdrowienia, HE
...MANY THANKS....I BOUGHT ONE YESTERDAY...WE WIL SE WHAT HAPPENS....THE WEIRD THING IS THAT BOTH OF MY ST16, SHOWED THE SAME PROBLEM AT A DISTANCE OF TWO HOURS...NOT SURE YET IS AN HARDWARE ISSUE...... I COULD OPEN THE PAD MENU AND THE WIFI SETTING MENU IS SHOWING " WIFI OFF" AND, IN THE MIDDLE OF THE SCREEN THERE IS A MESSAGE SAYING " Turning Wi-Fi on...." thing that never happens....do you think that a FACTORY RESET, could help?...many thanks....
Jesster0430
