Startup issue
t
  • Calibration or syncing
    Votes: 0 0.0%
  • Gps,camera
    Votes: 0 0.0%
  • Total voters
I am having problems making the drone operate. After turning both the controller and drone on and once it seems to be done loading all it does is it beeps and the lights under each motor and there are 2 lights red and two right and another red light under drone and flashing. In the past it started bu then as soon as i accellerated it would flip over and damage blades. Now i cant even start the bladws turning. I dont know what im doing different. The only other thing ive did is install 2 SDmicro cards. Does anyonehave any suggestions or from what i explained how i can diagnosis the problem
An initialization error means there is a failed component in the craft preventing proper startup. You need to connect to a computer and run the GUI program from Yuneec. It should be able to tell you where the trouble lies.
jonnyelectric
