Regardless of what you fly, don't fly anything in the area and during the period covered by the TFR. Really bad Ju-Ju if you do.
RENO, NV ON WEDNESDAY, AUGUST 23, 2017
Click here to enlarge image
A NOTAM has been published (FDC 7/6314) that will affect flight in the area during President Trump's planned visit.
30 NM RADIUS TFR
On the MUSTANG VORTAC (FMG) 227 degree radial at 7 nautical miles.
From the surface up to but not including 18,000 feet MSL.
Times:
10:00 AM local until 12:30 PM local Wednesday, August 23, 2017
10 NM RADIUS NO-FLY ZONE
Affected Public Use Airports
KRNO Reno/Tahoe Intl
N86 Spanish Springs
KRTS Reno/Stead
KCXP Carson
A34 Dayton Valley Airpark
KTRK Truckee-Tahoe
KSPZ Silver Springs
N58 Tiger Fld
O79 Sierraville Dearwater
KMEV Minden-Tahoe
Additional Notes:
No pilots may operate an aircraft in the areas covered by this NOTAM (except as described).
Except as specified below and/or unless authorized by ATC in consultation with the air traffic security coordinator via the domestic events network (DEN):
A. All aircraft operations within the 10 NMR area(s) listed above, known as the inner core(s), are prohibited except for: Approved law enforcement, military aircraft directly supporting the United States Secret Service (USSS) and the office of the President of the United States, approved air ambulance flights, and regularly scheduled commercial passenger and all-cargo carriers operating under one of the following TSA-Approved standard security programs/procedures: aircraft operator standard security program (AOSSP), full all-cargo aircraft operator standard security program (FACAOSSP), model security program (MSP), twelve five standard security program (TFSSP) all cargo, or all-cargo international security procedure (ACISP) and are arriving into and/or departing from 14 cfr part 139 airports. All emergency/life saving flight (medical/law enforcement/firefighting) operations must coordinate with ATC prior to their departure at 916-366-4080 to avoid potential delays.
B. For operations within the airspace between the 10 nmr and 30 nmr area(s) listed above, known as the outer ring(s): All aircraft operating within the outer ring(s) listed above are limited to aircraft arriving or departing local airfields, and workload permitting, ATC may authorize transit operations. Aircraft may not loiter. All aircraft must be on an active IFR or filed VFR flight plan with a discrete code assigned by an air traffic control (ATC) facility. Aircraft must be squawking the discrete code prior to departure and at all times while in the TFR and must remain in two-way radio communications with ATC.
C. The following operations are not authorized within this TFR: flight training, practice instrument approaches, aerobatic flight, glider operations, seaplane operations, parachute operations, ultralight, hang gliding, balloon operations, agriculture/crop dusting, animal population control flight operations, banner towing operations, sightseeing operations, maintenance test flights, model aircraft operations, model rocketry, unmanned aircraft systems (UAS), and utility and pipeline survey operations.
D. FAA recommends that all aircraft operators check notams frequently for possible changes to this TFR prior to operations within this region.
30 NM RADIUS TFR
Times:
N86 Spanish Springs
KRTS Reno/Stead
KCXP Carson
KTRK Truckee-Tahoe
KSPZ Silver Springs
N58 Tiger Fld
KMEV Minden-Tahoe
Additional Notes:
