Typhoon H arm latch replacement (metal part in main body)
I need to replace 2 of the aluminum catches that snap into the arm metal retainer.
Is there a video on how much of drone I need to remove to get to the retaining screws?
Tim
You don't need to disassemble any parts of the drone.
Using the small screwdriver, remove the very small Phillips-head screw, take out the spring mount, and replace it with a new one.
This takes about 1 minute per arm.
You do need to remove the top shell. Remove the six 1.5mm hex screws from around the edge of the shell. Unsnap the latches on each side of each motor opening. Disconnect the GPS connector.
I had to remove the bottom cover and the Landing Gear servos
It was the cast clip that broke not the stamped metal piece in arm.
Tim
BlezzWon
