Typhoon H drifting
The last two flights I have flown, my TH will not stay in hover. It drifts around in all directions requiring input from controller to keep in one spot. Anybody else experiencing this?
Have not since the first time i took it out of the box. Will do that today!
Yes, re calibrate. You should always do that if you notice any odd drifting around behavior as a first attempt to solve the issue.
Where did you do your first calibration? Far away from buildings/steel work etc?
The calibration issue has been debated to death. I think you need to calibrate the accelerometer. If it's not flying away then compass is probably ok. TH is heavily GPS controlled.
Maybe its time some of these common issues were made sticky??? just a random thought from the peanut gallery....cause common sense aint so common!
Reactions: banned user
First calibration was in the middle of a parking lot away from building and away from my cell phone. Thanks for the input
Remember that if you do hard/bouncing landings you might have to recalibrate.
Being a helicopter pilot as well as a drone pilot, I am very aware of hard landings and bounces - so I have made sure that I don't bounce the drone off the ground as I'm still trying to figure out just how sturdy it is. Too much money invested to bounce it off the ground.
Guess we are blessed to have a compass, barometric sensor, GPS, and dedicated camera. Means there're lots that can go wrong. HIP you don't know or maybe don't care but we have a bunch of PPLs rotary pilots on here. The videos here are much better, we don't haf to take a door off to take a great picture.
I've noticed my H slightly veers/drifts to the right when going forward but keeps a straight line when coming backwards, I'm not sure of the cause but I need to balance the props so I can rule out that variable, when I checked them they are out of balance as others have noticed, I also noted one prop was 1 gram heavier that the others, now as it was supplied complete with ten props in a bag Its quite possible by now I have used every prop in the bag at sometime so the one heavier prop is more than likely been fitted at sometime, so I'm not expecting this is the likely cause of the slight veer/drift to the right, any suggestions appreciated.
Sparkorc sometimes we inadvertently push the right cyclic off centerline. Pay attention next time you fly. Fly safe.
is there any order in which you calibrate ..... or does it not matter ... and while I am asking how often .. thanks in advance
I did the compass first, then the accelerometer, then the camera gimbal. It was only the second time i have done this (first being when I unpacked the unit at initial shipment). I would say that I will do this on a monthly basis just to keep the unit in calibration.
Reactions: Jim Davies
fotozone
