Typhoon H no telemetry data after update
What to do if select the “SR24_XXXXX” under the “Aircraft Model” column, nothing shows up in the Aircraft Model column? I can bind camera(CGO3+), but not aircraft, because it don't appears?
Please help if someone knows - what i need to do?
What color is the Main LED on the aircraft??
If it is flashing blue it means it is not bound to the controller, tilt the aircraft forward at least 45 degrees two times to get it in bind mode with main LED flashing orange, then refresh the bind screen on the controller.
You are right - it is fashing blue. Tilting doesn't change anything... it flashes blue so far. Now i need charge a battery - i will try again a bit later. Anyway, thanks - i didn't found this solution even in not OEM manual :)
You can find the binding procedure on page 43 of the attached manual.
  • TYPHOON H USER MANUAL Vcho3-2.pdf
DHYradio
