There should be holders molded into the frame just in front of the legs:
This Help?
The Lock Washers are for Shoulder Bolts that are Basically the Hinge for the Motor Arms, the 4 screws are the Landing Gear Retract Modules, the smallest screws are for the Motor Arm Navigation Light/Status LED PCB's.
And your welcome for the Fasteners...
I have built 2 from the frame out be glad to help anyway I can!The build is pretty much the same as an H. As to the landing gear, it slides in and there will be a place for a hex screw on either side to hold it.
I also have 2 issues I need help with.
1. Not happy with battery door...I only get one click, not two..the battery is easier to pull out then my other h plus. Any suggestions?
2. I stripped a screw on the lampshade. I tried the rubber band trick and it didn’t work. How do I get it out, any other home remedies or something at Home Depot/Lowe’s? Can’t drill it out as you normally would with a stripped screw, it’s just too small.
I need to open it back up and place the 4 large screws I have left over (can’t be good leaving them off it)
Congrats to you,to get this far. We have followed you through this and thoroughly enjoyed it,all the while hoping for your success. You didn't even once lose your cool. Good luck with camera setup. KCDid it work...?????
Sorry for the crappy video and editing, it was just with an iPhone and I hurriedly put it together..
Yes I calibrated compass but didn’t video it to bore anyone
And thanks for all the feedback folks!!!!
For stripped screw head,I have done this, insert wrench with gorilla glue or epoxee,something that hardens and carefully turn it outwhen dry.Someone used to make a liquid mixed with small metal particles,,very small and you put it in the screw head ,insert driver and turn,it did work sometimes. That's all I got KC
Not if the 4 large screws are the landing gear screws. You have to put those in AFTER the shell is in place. Or did the screws turn out to be something else?I need to open it back up and place the 4 large screws I have left over (can’t be good leaving them off it)
The first click is usually when the lock on the batt passes just under the frame/shell. If you can't pull it out with your finger nails, it is locked. If you do remove the top again, check it to make sure the lock is fully engaged.1. Not happy with battery door...I only get one click, not two..the battery is easier to pull out then my other h plus. Any suggestions?
I have successfully used a torx driver to remove a hex screw in a case like this.I stripped a screw on the lampshade.
