Is it still in warranty?No never had a hard landing, happen to fly only twice till date.
Hello Steve,Is it still in warranty?
I was contemplating to replace the camera unit, perhaps the cost appears to be almost 70% of the entire unit costIs it still in warranty?
There are some on eBay for $400 - $500 USD.
It would be be cheaper to have a dealer check out your camera. Is there a dealer in your area?
Don't Vertigo drones or Terrestrial imaging have a eBay page? Some of the dealers here do?Yes true Steve, but they are not authorized dealers and are third party who deal with all of the brands, i am bit apprehensive to give it to them for fixing the issue.
Thank you very much ,let me check it out.Don't Vertigo drones or Terrestrial imaging have a eBay page? Some of thedealers here do?
Hello All,
Could you please tell me where i can buy the camera C23 accessory online for the typhoon h plus, since i want to replace it due to gimbal issues typically vibrating violently after the FW updates?
Will appreciate your response. Thanks
I may have found a firmware fix. I'll know by tomorrow.I also had a vibration on the c23 gimbal. The vibration stopped whenever I held the platform right above the camera ( lower end of the dampers). If your gimbal performs the same way, then my solution may work for you. I added smalls weights to the four corners of the platform. Total weight was less than a penny. Good luck
Hello Steve,I may have found a firmware fix. I'll know by tomorrow.
