Typhoon H probleme gps
Bonjour à tous, mon Typhoon ne prend plus les GPS, la console indique 12 GPS au dessus à droite et sur le côté à gauche, mais reste en acquérir en rouge. Il ne peut plus décoller. ... J'ai tenté plusieurs endroits et même chose. ....Pouvez vous m'aider ? Merci
How long are you waiting on the ground ? You need 14 satellites minimum to be able to take off. If you can never get more than 12 that suggests your compass is broken (or its battery has gone flat) and you should investigate getting a replacement.
The number on the left shos the number of sattelites your Typhoon H found. The number in the upper right shows the number shows the number of sattelites found by your remote. Since the numbers do match, I do not expect something to be broken.
The remote as welle as the Typhoon H need some time to acquire GPS. Furthermore obstacles like clouds, trees or buildings can cause problems finding GPS.
markcareengi
