UAV Toolbox
Afternoon All,
Quick question to do with UAV Toolkit, can you plot a flight along a straight path of say 800 meters and also instruct the drone to stop hover and take a picture every 200 meters and then return to home ?
Cheers
Steve
UAV Toolbox is only compatible with the Typhoon H and H Pro... it is currently not usable with the H Plus. However even on the H and H Pro, UAV Toolbox does not have mapping capabilities.
Reactions: Steve0510
thankyou, manual flying it is then !
If this is a route you will be doing more than once, you can program a CCC route, save it and run it each time you want to do this. Here is a video that can help
I use UAV Toolbox to map subdivisions. The largest one I have done so far is 75 acres. UAV Toolbox allows you to create a CCC route, then using the timelapse photo feature programmed to take pictures at 1 second intervals, fly the route. You now have about 1000 pictures for an 18 minute flight. Use webodm to stitch the photos together or create 3D maps, overlay on to Google or GIS maps.
Never mind....
-Roseann Rosannadanna
  • Haha
Reactions: RatBob
Reactions: Phaedrus
Gilda Radner
Reddybook
