Looking forward to the release of your converter. It appears you have done a very good job with this. I should be freed up a bit in a week or so and would be able to do some flight testing.
Thank youTo unlock waypoint mode, you have to bind your H480 aircraft as H920, yes that's all (check first post).
My converter is for Windows only now, maybe in the future i'll release android version or at least html version to use with ST16 browser.
Thank you. Wow, I am impressed. My Typhoon H pro is now a Typhoon H plus with these waypoint features.To unlock waypoint mode, you have to bind your H480 aircraft as H920, yes that's all (check first post).
I understand, Thank you. As long as I can do Mapping/Surveying missions with the camera looking, at least, at what I am surveying, I am happy with it. Will give it many missions to get used to this set up. I don't need the picture quality of the C23 camera for Mapping and Surveying, the CGO3+ 4K quality is good enough. Now I don't have to purchase the Typhoon H Plus just for mapping/surveying, with this hack, I am able to get what I need out of my Typhoon H480. Thanks Again. God Bless.Just be careful when flying in waypoint mode, read Yuneec Manual for Waypoint App H920 and practice how and when to use S4 switch.
Check first post for tutorials and workflow if you are interested in survey missions.
Remember this mode can't control CGO3+ camera(or it is very limited) and converter is made for MAPPING/SURVEY missions, not cinematic shots etc.
After spending 120 minutes in air with H480 in Waypoint mode i can tell you this is the cheapest platform for mapping, it's not user friendly, it's not easy, but for 400$ you can't buy anything close to H480 with CGO3+.
This month i'm doing a <100 acres mission, got half of it for now and for next parts of this mission i'll be using two ST16's and maybe i'll make a short video from the field.
Stay safe Pilots.
Just so you know, the Typhoon H Plus does not have mapping and surveying built into its software. You have to have the H520 to do that, using the DataPilot app that is used to plan these missions. The H Plus does not have the ability to switch to the H920 model that @howfastyes has made the converter for.I understand, Thank you. As long as I can do Mapping/Surveying missions with the camera looking, at least, at what I am surveying, I am happy with it. Will give it many missions to get used to this set up. I don't need the picture quality of the C23 camera for Mapping and Surveying, the CGO3+ 4K quality is good enough. Now I don't have to purchase the Typhoon H Plus just for mapping/surveying, with this hack, I am able to get what I need out of my Typhoon H480. Thanks Again. God Bless.
I have the Typhoon H480Just so you know, the Typhoon H Plus does not have mapping and surveying built into its software. You have to have the H520 to do that, using the DataPilot app that is used to plan these missions. The H Plus does not have the ability to switch to the H920 model that @howfastyes has made the converter for.
So do I and it is the one that will allow you to select the H920 model.I have the Typhoon H480
