Updates
I've been trying to update this St 16 send via SD card but it keeps asking for wifi connection why is that and what is the version that it should show after upload
although I have updated new firmware for the st16 and camera, I'M not getting the options for using burst setting
Have you followed the steps in this video?
although I have updated new firmware for the st16 and camera, I'm not getting the option to use the burst setting in [photo mode is not lit up on screen
Make sure you are in photo mode, otherwise you won't be able to access photo settings. Also pick CGO-3 Pro in "Select camera" tab in settings and finally in "other settings" you should check the "advanced mode". Let us know if this helps.
Make sure you are in photo mode, otherwise you won't be able to access photo settings. Also pick CGO-3 Pro in "Select camera" tab in settings and finally in "other settings" you should check the "advanced mode". Let us know if this helps. thanks guys, i was not in photo/ was in video.... LOL
Glad it helped, oh and don't worry, it happened to me too when I was beginning my journey with my Typhoon H :)
snoopy68
