USB Interface / Programmer Gimbal Adapter Lead
What is the purpose of this cable and how is it used....?USB Interface Programmer Gimbal Adapter Lead Wire.pngUSB Interface Programmer Gimbal Adapter Lead Wire.png
This was an adapter for programming inteface (USB to serial YUNA100 or BLH7840) to a old camera CGO2 or older. It has no sense anymore at Q500. CGO3 does not react to the serial connection.
I use the plugs for other purposes (cut it in the middle), i.e. to connect an SR24 receiver to the Blade 350QX to control it with ST10.
I have it with usb connected and 2 of them.. I get last end off and connect inside battery compartment cable and USB in windows computer gui software and then you can change hight motor calabration etcc
Btw the serie from the old Kabel is finish for long time.. Now you get usb with 2 kabels on it
Cj42804
