Video CC Mode, POI and resolution test UK
london UK
Still lots to learn. Important to remember position of switches. Cable Cam, POI and Orbit modes do not override the Pan Mode switch on the left. It has to be in Global mode right down. Also if you lose the wifi link three things happen. The camera switches OFF. The mic also switches back to OFF the default. If you were in manual mode for Exposure it returns to AUTO. They all have to be reset. Most definitely if you do not put the Pan Mode switch right down to Global you get a very odd point of interest shot. Also my camera seems not to be realigning itself properly. And to start all there modes there is on screen slider switch to make them start. It will take a while to get use to these procedures.
how do you get it to zoom? is that in post or while flying
How about cc mode, can you save route and fly it again after change battery. Does controller save it and is it possible to load afterwards?
Yes you can save the waypoints on the controller for future use. Once saved you can access the list of saved waypoints by pressing the List button in CCC mode. Odd label, perhaps they should have called it Load.
Thanks, it sounds good. Not received my H yet...
If you are recording when you lose the video feed, the camera should keep recording and the settings should stay the same.
Sierrarhodesss
