Please add the documents as PDF's in the WTFD project.
To raise the interest is the best to make a fast look instead to go to some links.
Yuneec- specific data and control message formats (Yuneec MAVlink
messages, SR24 messages, GUI messages):
 H480_UART_readin.....
Link is wrong and produces 404.
This is unreadable as PDF.
I referred to Vaklin's post #102. The format sheets exported to PDF produces useless and unreadable PDF files. Useless because you cannot select and scroll that messages which are often too long for a PDF sheet.
Sorry for misleading expression.
Revision 06
Added a new section for "Normal Binding Process Videos"
to provide links to videos of the normal binding sequences when no technical issues require use of the Binding Verification documents.
Date of revision: 05/13/2025
Kkit
