Added new Attachment 47 (Typhoon H Plus Flight Log Retrieval). Very similar to existing guidance for Typhoon H, but enough difference to benefit from a standalone attachment.
Great, very tksThis document is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
The intent is to provide a resource for issues related to our hobby. If you have any guidelines, drawings or useful information, please post in this thread. You will be given credit for the information. Material covered by copyright will not generally be useable. However, links to the original information generally will be. Links to YouTube videos you found informative may be useable. Use of all links to external media must conform to Forum Guidelines.
Date of latest revision: 03/14/2020
The attached document was recently developed to assist a member in diagnosing a failure of motors to start on a Typhoon H. The document has been added as new Attachment 35 (ST16 GPS Test) to "Way To Fix Drones project"Date of latest revision: 05/17/2020
You might want to look at Attachment 19 (CGo3+ Stuck Mount Contacts) first. It's the easiest thing to check, and accounts for a fair percentage of the failures.
If that isn't the issue, then look at Attachment 54 (Typhoon H / CG03+ Continuity). It shows the path all the way from the drone mainboard to the slipring connector on the camera gimbal board. Most problems are a blown "K" fuse on the mainboard, a loose connector on the backside of the drone's "hotshoe", the stuck springs on the hot shoe you checked in Attachment 19, or a damaged slip ring. But other things do happen.
You mentioned this is a new camera. If the old camera has power, you don't have to check the things on the drone, and can start at the top of the camera mount.
Ok I’ll check now and let you know, thanks a lot for the supportThis document is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
NOTE: Once you are in the document, scroll down the MENU to find the Attachment you need. Click on either the Attachment Title or Attachment Number, and it will take you to the actual Attachment.
Date of latest revision: 06/29/2020
Cannot open, like last time, download unsuccessful....?
