Documents and firmware related to the original H920, the ST24 controller and the various cameras are becoming hard to find. A repository has been established for the original H920. An entry was added to the "Table of Contents" version of the WTFDproject Document that links to the new file repository. The repository itself is a fledgling gathering of data, but members have already added substantial information. It is hoped more will continue to be added.
Added "Typhoon H Brick Recovery" guidance to the Menu Driven version in the "Typhoon H and ST16" section.
This guidance is intended as a possible recovery path for a bricked Typhoon H. The guidance links to the required firmware.
Edited PDF Step 1 to provide better access to the required files.
@WTFDproject, You sure have been a busy "young man"
Date of latest "Table of Contents" revision: 10/03/2024
Added new section for "ST16 Series Controller Conversions".
The new section is added only to the Menu Driven Version. Refer to Page 4 of the attached "Table of Contents".
Reactions: h-elsner
4 more sounds:
Accelerator calibration with final reboot
Manual switch off and on GPS
Motor/ESC error for motor 2 to 6 (number of the following beeps after the main indicator)
Motor start rejected due to unfinished pre-flight check (aka GPS aquiring)
4 more sounds:
With thanks to @h-elsner , these new sounds are added to the existing link in the "Table of Contents" version of the document.
Reactions: DoomMeister
This document is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
The intent is to provide a resource for issues related to our hobby. If you have any guidelines, drawings or useful information, please post in this thread. You will be given credit for the information. Material covered by copyright will not generally be useable. However, links to the original information generally will be. Links to YouTube videos you found informative may be useable. Use of all links to external media must conform to Forum Guidelines.
NOTE: The WTFDproject.PDF is a collection of attachments arranged by attachment number. It contains its own menu at the front of the Document. Once you are in the PDF document, scroll down the MENU to find the Attachment you need. Click on either the Attachment Title or Attachment Number, and it will take you to the actual attachment within the same document.
NOTE: The "Table of Contents" version attached is a compilation of direct links to individual articles and may be more convenient for many. The articles in this format are grouped by subject/title rather than by Attachment number. The articles in this format are also significantly more up to date.
Date of latest "WTFDproject.PDF" revision: 03/11/2022
Date of latest "Table of Contents" revision: 11/08/2024
Added new guidance for H520 ULog (flightlog) retrieval to the "Table of Contents" version of the document.
Date of latest revision: 04/14/2025
The former single PDF version of the "WTFDproject Document" had become too large and too far out of date for practical maintenance or use. The single PDF version has been retired.
The links in the Menu Driven version have been brought up to date.
Reactions: Pier2162
I thought John had been hosting this?
Good to know. thanks
kybelvody
