Backpack and batteries received - photos
The first vendor I went with through Amazon cancelled all preorders because of a 30 day limit by Amazon. Now I'm waiting on my second pick, but I got a better spot in line for whatever that's worth. So the wait goes on...
View attachment 470 View attachment 471 View attachment 472 Okay, I went to my Post Office to get my mail, took some quick photos. The backpack seems huge and I wondered if it was carry-on compliant, measured roughly as 19" x 14" x 12". I know some are interested in battery terminals, so photos shown of those.
Need to test the points to see what the voltages are. While it's a 4s battery there is 3 test point (round holes) so a tap off point between batteries (3).... Strange there are 3 other points (square) one is positive, one is negative.... What's the other? Is that another negative point? Strange. I'm guessing the 3 small circular are the B1,B2,B3 test points between the cells, two of the square are the B+/B- points so this allows me to check voltage at each cell and the total.
????? What is the other square connector for? 3/4 voltage tap for controller ?? Can't wait for someone to check the points and get back with us as to what they are...
So does the first 2 plug points on the battery look just like a Deans Plug type??? Hmmmm
Reactions: HarveyC
I know enough about electricity to give myself a good shock but, if you want me to take any measurements, including with a meter, let me know. If you happen to be in NorCal you'd be welcome to check one of them out.
Put your digital VOM in each port black/red leads separately one at a time and post readings, i am curious if it is left in the dock it will discharge the LiPo to recommended storage voltage of about 50%, but then it is not worth it as you do not have a charger to fully charge it, correct Harvey?
Looks pretty standard. All that needs to be done is for someone to take one apart and do some designing.
Reactions: DroneClone
My readings are essentially the same, 3.86v, 7.73v, 11.60v, 15.47v, 15.47v.
Hey guys, just received my extra battery and backpack, I have taken pictures of it next to my carryon suitcase I always travel with. As you can see, it is short height wise but definitely has more depth. I do not think it should be a problem boarding a plan with (hopefully). I guess I will find out soon, then again, I have to have a drone in it to even matter.....sigh.
It will be a problem with smaller planes, I believe. Southwest limits the dept of the carry-on baggage at 9" and I measured this to be 12". Even when I last flew on a 747 I had a later leg of my flight on a smaller aircraft. I may look into making my own carry-on case for the H and put the backpack in a large duffle bag to use once I arrive at my destination.
Yeah not getting this in the over head bin. Very flexible but after getting the insert inside it may get stiffen up.....
Dvca441772
