- Joined
- Mar 26, 2019
- Messages
- 196
- Reaction score
- 175
Pilot is not online, because he definitely thinks the prop bent and drone fell, his ego doesn't allow him to consider any other solution, pilot's pride....
Therein lies problem number 1.
Pilot says to be experienced in flying.I'm going to call this pilot error. Don't see any telemetry on the battery voltage. For the sake of argument, if the prop did fold, it would have gone into five motor mode where the pilot could have landed it. How experienced is this guy?
yes I've noted pitch +20/-20 seconds before fall. (and altitude log stopping at 8 meters) do not understand how this pitch change could bend a propLooking at the graph showing pitch, roll, and yaw of the craft it was not stationary when the trouble started. There was close to a full forward pitch command for around 3 seconds at the 45:00 mark then a full reverse pitch command for about 2 seconds at 45:04. A full left yaw command started just past 45:06 and that is when things went bad. The aircraft continued to spin left and pitched violently forward then back and oscillated lifted and right by 150 degrees as it fell from about 60 meters.
My take is that there was a mid air collision with something. The prop did not just bend like that in flight and cause the crash. I also find it hard to believe it bent without cracking. That looks more like the result of heat applied to the plastic after the fact.
Blades are not from Yuneec,Are those OEM blades? A blade at that angle would have shattered. This looks like a very cheap plastic from another manufacture?
I a bit confused, one picture shows the bird yellow the rest orange?
Pilot reports to have seen an arm break just before fall. He explains the arm broke due to heavy vibrations from bent blade. (which I doubt)
I would say this is a very defective blade.
I've only replaced 4 of my original OEM blades with a new set of OEM's, many moons ago.To break a carbon fiber arm by vibrations only means that they have been brutal. In that case it is clear that it has been one of the propellers.
With the original propellers, they recommend to change them every 20 flights, that would be only 7 hours. I find it too conservative when a colleague here has reported that with a Tethered Power System 24h of continuous operation.
It would be interesting to know, those propellers how many hours they had flown. Anyway a manufacturing error can always be found.
The fact to change the propellers, to put of another brand, to that it was due? I say this because those of the H520 are not cheap, but neither excessively expensive, considering that it is a fundamental element. They gave more performance?
1. A motor did not make a clean break because of a bent prop. The flight controller would have detected a high load on the motor and would have shut down the motor. The fact that the wires are also severed is a clue.
2. Using aftermarket props is foolish. They are known to fail in-flight.
3. Upload the logs please, not just a screenshot.
4. This scenario is more likely to be a result of something like the video below.
