Best 4k video editing software
Hi, advice please on video software
I am using video at 4k to survey buildings and currently just using Media Player to get stills from the video.
Any recommendations or suggestions for the best editing software?
Being able to crop in live while playing the video and re record would be good.
Cheers
Mike
I was hoping to film in 4k allowing me to zoom in a still pull good quality stills from it.
Sadly Video Editing software degrades the resolution as you zoom in. I find my system called Edius will only allow a small digital Zoom in with out losing definition. And it is very expensive as well. So be careful before spending a lot of money.
Reactions: Nobert
Jumped through a lot of hoops today to test Premiere Elements. Was NOT happy with the 4k renders. Picture quality was inferior, lots of blocking. It insists on rendering 30fps clips at 60fps, can't adjust, no choice of codec, supposed HQ renders came out a third the size of LQ... Scratching it off my list, wasted the better part of today on it.
Reactions: TopFlightTexas
Ok well Movie Studio Platinum 13 looks promising. Rendered files are twice the size of the originals though so they better look good and they do, (in very quick testing) but don't play back quite as smooth as the originals. The trial doesn't have the annoying watermark like Adobe's either. All I initially really want to do is simply cut the best shots from the original footage, but with today's complex codecs it doesn't seem to be possible without at least a little transcoding. I've been out of the game for a bit so catching up on what's out there...
Sorry to drivel on but apparently one can save some bucks by purchasing the version on Steam for a not too bad 60 dollars.
Very strange i'm using Adobe Premiere Elements now some time and i'm very happy with the quality of the rendering. What was your original footage configuration (resolution, bitrate, coded, ect ...).
Of course adobe premiere elements is a poor man version of the full blown adobe premiere. I think you have to try that one, has a lot more rendering functions and settings ...
But if you only ned stils you culd use adobe photoshop, you can import a vieo and make stills of that ... as you now photoshop is the best photoediting software on the market ...
/\/\ax2206
Full HQ straight outta the H. 4k video, 50Mbps bitrate, AVC, here's the full details:
General
Complete name : D:\Drone Flights\Quartz mtn 053016 64gig card\YUN00008.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 59.7 MiB
Duration : 10s 10ms
Overall bit rate mode : Variable
Overall bit rate : 50.1 Mbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 10s 10ms
Bit rate mode : Variable
Bit rate : 50.0 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.201
Stream size : 59.7 MiB (100%)
Title : #Yuneec AVC
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Full
mdhd_Duration : 10010
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 10s 5ms
Source duration : 9s 984ms
Bit rate mode : Constant
Nominal bit rate : 128 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz
Compression mode : Lossy
Source stream size : 55.3 KiB (0%)
Title : #Yuneec AAC
Language : English
mdhd_Duration : 10005
gbare
