Good question. I'm not sure either, but I would start with the sd card. I'm not certain which folder the CCC flights are stored.Hi friends,
I am planning a fly with program "hplan" and whit " ccc" and i don't know where i have to insert the files y dowload when i finish
Can help me please??
Where insert the file, in sd...??
Once you open the "flightmode" folder, there should be a "mission_data" folder. If there is not, you might have to click the three vertical squares in the upper right corner, then choose "settings", then check the "Hidden files" box.Hi friend,
Very good help, but where is "mission data"??
In my internal storage is not this folder ("mission data"), is flight mode only.
I need to create this folder??
what have i do?
regards
