As far as I can tell its still legal for hobby flyers to go above 400. why yuneec would make this limitation is beyond me. Unfortunate.
Cant at all now mods or not... at least not with the ST16.
I find it funny that they would add the ability to turn the lights off which is illegal at night technically but remove the ability to adjust the fence.
So far no luck rolling back....Well that sure limits what I can do in the hills.
Have to make use of my other copters for that I guess.
Or role back your software while you can
500feet or meters? 500 meters is like 1000+ feetI think DJI has a 500meter limit which makes a lot more sense.
I am still talking not more than 400ft above ground level.......the top of a cliff, or hill. From where I stand it could easily be six or seven hundred feet altitude, but legal 400ft agl
used to be that way. You used to be able to use the GUI to adjust it but now you can not.Thought I read somewhere it was software limited to 400ft by default, but could be changed to a max of 500 meters. I may be wrong on that. I shall look into it.
I had no gimbal issues. I will try Journey. As for the trim pad. Maybe try turning on advanced... mine is working but i turned on advanced right off the bat. Also trim pad does nothing unless in the air. Well... it shows little tiny icons going up and down on a graph box in the bottom right. Did not notice at first. But once in the air it does control trim. Not exactly the ways i would of liked but... it works. Might function more how I want if you can use the trim in POI mode, have not tried. The fine tune ability would be handy there.Tested new firmware today:
1. Would not fly above 118m (387 ft) even though set higher with GUI. I understand Yuneec is working on a fix.
2. I cannot find where to enable trim pad features. I get big message box when I press trim pad but nothing happens.
3. I could not get Journey mode to start. What am I missing?
4. Had to reboot TH 3 times to correct gimbal drift (even after 2 gimbal calibrations). Eventually OK.
I really do hope they "fix" / return the GUI's ability to adjust max alt.
