It happened to me twice this year, the first one is for repair or refund from Yuneec USA, the second one is out of guarantee. I am waiting from Yuneec , but now I am afraid it can Happen again, did you find what was the cause with your‘s ?This morning, my Typhoon H lost total power about 2 minutes into its flight, in an arc across the outside of a hill. It was at 40 meters high on a clear day. It had a fully changed battery that was firmly secured with the latch down and locked. It simply lost total power are dropped straight down like-a-rock flat on to the short grass on a gentile hillside. The camera and gimbal was crushed, mashed, and torn off. Each leg (in the up position) with broken foot. Two broken arms. Cracked battery - half out of its bay. Cracks in the lower body. Three broken props. See attached flight log. It shows the spin out just before it lost power under perfect conditions. You can see all was well in this image of the last Flight Log Telemetry readings before the power loss. Notice hoe the yaw suddenly changed in the last 2 entries!
It looks like a total loss. No other pilots were in the area. It was a routine flight in a well flown practice area. I can't explain what happened. There was nothing I could do to recover. I guess I was lucky it didn't happen on a commercial job or over real property or people!!!
I called Yuneec, sent them the flight log, and they sent me a RMA with a pre-paid UPS shipping label. I have to wait and see what they say after inspecting the damage. I hope they'll send me a complete new unit with Real-Sence and the new 3 antenna transmitter too (I can hope & dream).
Has anyone else had any similar experiences?
A common reason for a TH to fall from the sky after a total power loss is that the battery has not been inserted correctly...not been locked into place. Inert the battery firmly so that you can hear the click as the locking latch engages. If you don't hear the click then push it in until you hear the click.It happened to me twice this year, the first one is for repair or refund from Yuneec USA, the second one is out of guarantee. I am waiting from Yuneec , but now I am afraid it can Happen again, did you find what was the cause with your‘s ?
I do not see many cases like this in the forum, so need to know if I am doing something wrong, like not installing the battery correctly, but the ST16 did not show any error, and was fully charged, I use the Yuneec batteries only.
Let me know if you find something about it
Perhaps more information would be helpful about that flight.It happened to me twice this year, the first one is for repair or refund from Yuneec USA, the second one is out of guarantee. I am waiting from Yuneec , but now I am afraid it can Happen again, did you find what was the cause with your‘s ?
View attachment 7198 Another thing I like my Graupner Polaron EX-1400 charger as it displays and graphs the I.R. During all charge functions so I also get to see what a cell is doing during charging, simulating a load or discharging for storage. Really a cool charger
Are you a gambling man? I probably assume not, treat it as an early warning. Prevention is better than cure.This thread scares me, because one of my battery is showing a weak cell.
Should not be a scare, but rather a relief!
As @Mrgs1 says... better to be proactive and remove something from service rather than find out during post incident investigation.
I've been following this thread and hope I'm not repeating what another has posted. What has bothered me each time is the phrase "was firmly secured with the latch down and locked". That is not a latch of any sort but just something to grab to pull out the battery. Whether it's up or down has nothing to do with the proper seating of the battery.This morning, my Typhoon H lost total power about 2 minutes into its flight, in an arc across the outside of a hill. It was at 40 meters high on a clear day. It had a fully changed battery that was firmly secured with the latch down and locked. It simply lost total power are dropped straight down like-a-rock flat on to the short grass on a gentile hillside. The camera and gimbal was crushed, mashed, and torn off. Each leg (in the up position) with broken foot. Two broken arms. Cracked battery - half out of its bay. Cracks in the lower body. Three broken props. See attached flight log. It shows the spin out just before it lost power under perfect conditions. You can see all was well in this image of the last Flight Log Telemetry readings before the power loss. Notice hoe the yaw suddenly changed in the last 2 entries!
It does have a latch and it locks quite well. Look again at the battery. When you lift the battery lever a lock on the top depresses to release the battery. It locks against an extensive of the main frame and cannot be removed unless you lift the lever.That is not a latch of any sort but just something to grab to pull out the battery
Thanks. I didn't see that. My concern was that after the battery is inserted to the point where you here the first click the position of the handle has nothing to do with the proper seating of the battery. I don't know where the main lock is. I do know that with the battery fully inserted and the handle lifted quite a bit of force is required to remove the battery. There's something, beyond that tab that's holding the battery in place.It does have a latch and it locks quite well. Look again at the battery. When you lift the battery lever a lock on the top depresses to release the battery. It locks against an extensive of the main frame and cannot be removed unless you lift the lever.
Indeed you are correct. I was being a bit lazy with my text.usually I can hear two cliks when I insert my battery.
