Ouch... had a fly away today
Now I am very confused. When you turn the GPS off mid-flight, do you get a compass calibration warning ? Like in UAV toolbox would that show as compass calibration warning?
The H suddenly went straight up in the air and I could not control it, I kind of got a little control over it and suddenly it started drifting downwind quite fast and I flicked the home switch but nothing happened.
I was about at 3ft when the H went up. I had a battery low warning just before that happened and I now assume that the H tried to fly home because of the battery warning. The battery was at 14.3 when I got the warning. I waited for it to give me the warning and figured I was safe since I was at 3 feet max. I think the battery just dropped in voltage suddenly. Same battery as last time when the H fell out of the sky suddenly.
I found the H about an hour later and only 1 prop broke, I found it on top of a bush and since it was making noises it was relatively easy to locate it.
I had flown for 19minutes I just realised (no camera attached, pretty windy, turtle mode most of the time and never higher than 5m, often turned the GPS off to practise flying with no GPS.
I think I am going to send the H and the controller to Yuneec and see what they say. It is scary to suddenly see your bird take off and drift away.
