2 controllers 1 drone
Twin Falls, Idaho
We have both st16 controllers binded to one drone and it shows the camera on both but only one controller runs it. How do run camera from one and flight from the other
Bind to one controller the one going to control the camera.
Then go into the menu and select team mode.
Then bind the 2nd controler.
Reactions: Graeme Buckley
It’s called team mode and it can be confusing first time. Bottom line is your main ST becomes camera control and the second controller becomes pilot with camera view. Both controllers can start/stop record or take pictures. You can make the joy sticks run tilt and pan by flipping the tilt mode switch down to position 3 or get the right stick for pan and left slider for tilt in position 2 (many people think that position does nothing but here it does) which I’ve found is better for some operators.
I had to read the instructions several times as the translation is lacking and it took a few tries indoors to figure out so I was capable in the field.
Reactions: Eagle's Eye Video
Jkent8541
