5.8 montor for Typhoon H
do they make a montior so a friend can wach at the same time I fly ON THE H OR Q500
Nope. What does work is using an HDMI cable to the monitor with the H. I can’t answer for the Q other than say it won’t broadcast to a 5.8 monitor either.
Yep - just get any tablet / adapter or field monitor with an HDMI in... search 'field monitor hdmi input' to find hundreds on amazon for example...
You can also use the HDMI port to sent the signal to the FPV goggles available for the H. Another way is to bind a second St16 controler to the H and use it in team mode. I am about to try this after getting a second remote as a backup.
For use with the ST16: $40
(I can't get my direct link to work)
Just go to eBay and search "Yuneec Goggles"
thanks
If you want to spring fir the big bucks you could buy wireless HDMI for both transmitter and monitor.
download the 'CGO' app onto a phone or tablet. Your friend can then use that device via the app which can log in to the typhoons wireless signal. Used it many times, very good.
Reactions: rockinh
It’s been quite awhile since I was reading about them. I don’t have further info so Google will have to be the “go to”.
Write your reply...
thiago jonas
