After market charger
Well called yuneec UK they said send it back to them so it's away today so hopefully get a new one under warranty
Ok while charging my 2nd yuneec battery today this has developed the same fault as the 1st one I just got replaced by yuneec what is going on here
Just found this on a site any members got 1 or used 1 now wonder what you would have to put ur aftermarket charger rate up to if 4 batteries on it
Stay away from the multi port charging boards.
They're bad news.
I have a couple and here's what happened to me....
On a multi port board, what one battery gets they all get.
I charged four batteries. My charger died on one leg (to much pull on charger) so all four batteries became seriously unbalanced on one leg. I spent hours trying to get all four back to a balanced charge that my charger could see and not give error warnings.
The boards are not insulated or isolated and if you get the board into some metal... a dead short is bound to occur.
My suggestion... stay away from the multi port charging boards.
Jmo :)
Thanks jafo for that yes I will stay away from them that's terrible that these are allowed to be sold
Jafo at the moment I keep my batteries in the case with my Q is it ok or should the batteries be laying flat
I must have an iMax charger somewhere in my storage room. I used to charge my Align Trex 450 Pro V2 lipos back in the days...
Question on the charger it gives input charge rate now am I right in saying this should be set to 12.6 volts
Hi here is the instructions if anyone can help with my question
  • charger instructions.pdf
Been away on Vacation...
I turn off the timer. I watch it enough it's not needed for me.
Your charger should taper off the charge as the battery fills up and should have a minimal trickle charge when it's done.
There should be no heat build up at all. If so, reduce the charge rate.
I start most of charge cycles at 5-6 amps and let the charger do the rest.
Thanks jafo For the 5400 yuneec battery I set at 5.4 and for the 6400 gifi power I set 6.4 that correct that way not puting too much in to damage
This guy ships to the UK.
The Duo comes with all you need to charge two Q batteries.
Venom Pro Duo Dual 80W AC/DC LiPo LiFe NiMH NiCd 7-Amp Battery Charger FREE SHIP | eBay
Happy Hunting.
Added: If you don't already have them, you might need a couple of these too.
10pcs JST-XH 3S Lipo Balance Wire Extension Charged Cable Lead 11.8" 30cm | eBay
Not quite true. you will need to buy a second EC3 charge cord and a second Yuneec cable/balance cable.
The Venom Pro Duo comes with one EC3 charge cable and 2 balance boards.you need to supply the balance cables (the cable you use to charge the batteries with the Yuneec charger).
loansjagat
