Anyone used the CGO4 in the proaction Gimbal?
That was the case with the CGO3 app for the Action grip as well... the solution as above, was the same... going out and finding an older APK file to get the app to work... Yuneec updated the CGO3 app in January, but I have been resistant to try the newest version... since I have not heard any confirmations on this board of success with that new version.
The CGO app replacing the CGO3 app work ok. Have used it a few times. Use it with audio recording in the iPhone with external mike. Only thing is I need the Mac and iTunes to retrieve the Audio files from the apps own storage - but it is synchronized mostly - saves a lot of time from external recorder. Pity to carry the Mac out to edit and match the video with the audio. Internal CGO3 audio is a disaster, but the external mike audio is ok depending on mike.
Hi All, how do you charge this gimbal ? Many thanks !
The system originally used the A10 charger that came with the H920 to charge the ProAction battery. You can use pretty much any aftermarket charger if you don't have an A10. You will need the adapters for the power connector and for the balance connector. Those items may come in some aftermarket charger kits, but you will need to check. I don't think they come in the A10 kit. They were packed in the ProAction kit itself.
The process is described on page 31 of the manual attached below.
maikol41
