Arm replacement issues!
Hey guys!
I broke an arm (motor) a while back, bought the replacement parts, opened up the dronne and the put the motor into the socket where it should be, but it wont get into the right position and lock the arm. The arm just lounges forward and the click I get from the other arms when they are put into flight position. So i disconnected the arm on the other side and now it wont lock itself into flight position either. (see pciture for details)
Is there something I am missing to get the arms to lock in the right position?
Thanks in advance!
I wish I had one in front of me to look at and analyze your problem. My only guess is that there is some sort of spring loaded detent that holds the arms in place when they are fully open or closed. Can you take a more detailed photo with the cover removed so we get a better look at the connection point?
The photos that Yuneec supplied to the FCC doesn’t show that area in much detail either.
jonnyelectric
