Battery indication
Glasgow
Hi folks I was charging 2 batteries on my DY3 went in and noticed 1 LCD screen said check balance port so I took the battery out and reinserted it and pressed charge and it's charging should I worry about it no swelling on the battery what's your thoughts
Reactions: KEITH KUHN
Sometimes they do play up, they have to be seated properly otherwise they can play up, sometimes when you first insert a battery one or two cells don't register and you have to wiggle it for all to appear. I don't believe anything is wrong, just watch it next time, check the battery in the next slot when you come to charge again.
Thanks mrgs yes it's still charging the other battery is charged so just this 1 has had to re seat it again chargingIMG_20190920_210019.jpeg
I have noticed similar problems with charger
that came with Typhoon H
I must remove battery
And reinsert it.
And reinsert it.
There's quite a few pins that have to align correctly, sometimes we don't get it right.
fotozone
