All your comments are negative. It could be interesting if you explained really and clearly your point of view or even better if you brought some NEW ideas or solutions but you don't.
You just always say: no! no! wrong! no! wrong! wrong! It is like this not like that! and so on.
This becomes more than a bit annoying!
On FB, you already had remarks from the forum moderator about the same discussion (you even went up to tell me I should go and consult a psychiatrist
) and I had to block you to avoid trolling in which you excels, please don't do the same here!
I think that during all discussion here I tried to be open, to learn, to explain things that I know or believe and to read and appreciate the constructive comments people here had the kindness to write giving details.
So, please don't post just to show you're here and that you know everything, mainly and in fact only what (you believe) is wrong.
If you write intelligent, detailed and substantiate point of view, I will be more than happy to read them carefully otherwise, just stop please!
We are not here to troll or pollute this forum and I don't want this to happen!
