Binding to multiple remotes?
Syracuse, NY
Hi everyone,
I am wondering if it is possible to bind to more than 1 remote at a time? I just got the Wizard and wondered if I bind it will it unbind the St-10+?
Thanks!
I found my answer. You have to re-bind every time you want to change controllers.
Well thats a pain. To bad there wasn't a way to switch off without going through the whole process again.
Reactions: dirkclod
binding is a pretty simple process - its too bad that Yuneec could not have made it interactive with the ST10 and use it as an add on so the ST 10 monitor would be used if needed to set the shot.
By the way the Typhoon does send a pretty good video if you want to monitor the shoot on your Iphone or pad!
x640536786
