So had a little mishap and the chroma hit the ground hard. I can find most of the parts I need but what I believe is called the damper plate for the cg02. The part that mounts from the slide mount on the drone to the top of the gimble with the 4 rubber dampers. Does anyone know if the cg03 damper plate will mount to the cg02 gimble and the slide plate on the drone? They appear to be shaped different but the holes look the same and the slide bars.
