Bond error
Receive this error before even try to connect, how do I solve this?
Put your phone in flightmode and disconnect other items connected to your phone via bluetooth and wi-fi. Then try to connect again.
That doesn't look like Yuneec Pilot app... At least not the one that I have
He’s probably try to connect via the program Qgroundcontrol? And it seems not to work. I’m not shure if the Mantis q can read that protocol even if it’s a px4?
Reactions: sschotte
It appears you're trying to connect using QGroundControl from a phone or tablet with Android or IOS.
You only need a 5 GH WiFi capable device, and connect to your Mantis Q AP using its SSID and password. Don't connect at all your controller.
Start QGroundControl and it will discover and connect. You need to configure video stream (rtsp://192.168.42.1:554/live ) and select virtual joysticks, they will appear on the main screen.
I use without any problem a Windows 10 PC with the corresponding QGC version:
17228
Reactions: DroneCalzone
So you successfully flew a waypoint mission with the Mantis? Can you confirm it's possible?
CBR26
