BREEZE!! GEOFENCE +500M
I can definately confirm in open areas with little to no wifi interference with a decent phone and controller these distances are easily achieved. With a wifi repeater I will predict the real limits are going to be battery level.
Do you guys remember your battery % out that far and did you use the new max speed to get there and back? Wondering what the penalty is for using it and if you could still do that same distance at normal max because the battery lasts longer.
Altitude testing would be different because the rate of climb hasnt changed. You could potentially fly very high with a much lower battery level left for return since the decent is so much quicker. It appears that setting isnt so easily adjusted.
I flew around with the speed setting at the new max and couldnt hear or see any issue even whacking the controls around to stress test. You definitely need to be careful with drift after letting off the throttle if you havent flown anything that fast.
I'm using the green apk and as u had said here with the drift, i noticed at least on my one breeze I've tested that if i let go of the forward joystick and I had speed all the way up , so the drone would drift until momentum was lost , that if i watch where the drone is when i let go , no matter how far the drone blows by that point of me stopping pushing forward the drone will drift slowly back to where i let go of pushing forward. almost like it took a gps snapshot of the point that i wanted it to stop at and once it slowed its self down and compared the two spots , the one it really came to rest at and the one i let go of the stick , it will slowly make its way back to that spot where i had let go
Good afternoon, today for the first time I reached a height of 400 meters with a converted repeater Comfast CF WR754AC (details in the attachment).
* For long-distance flight you need to use a directional antenna with a narrow radius of radiation, or use those cheep locators in my case.
* It is also important to direct the antennas towards the flight of the drone (look at the position of antenna on photo in attachment, in this case antenna is positioned to services drone flight in "" up direction).
Drone position must be parallel to antenna to get distance approximately 400 meters.
Remember do not rotate drone under it's axis, during your flight in "" up direction, you will lost signal.
* Don't forget to increase the speed of drone to maximum, because it takes some time to get so high, and then turn backwards.
If you're seeing that battery is low power, and you can't landing in time, use "Return home" button, its increase the speed of flight, and you will have a chance to land in time.
Can anyone advise a directional antenna that works well with Yuneec Breeze ?
Sacha
