Breeze
Hi....trying to finally get the time to get my Breeze up and running after purchasing 2-3 years ago. I believe I'm going to have to purchase a new drone battery because of it being dead. I've been charging controller for a couple days now and still getting blue flashing light....seems to be charging so will give more time. Although I could find app on my older Android, I'm having problems finding at this time on Play store with my newer Android. Is there another place I could go to download? I guess at the end of the day I'm wondering if Breeze is too far outdated to try to proceed with. Feel bad, haven't even had it running. Any help would be appreciated. Thanks!
If you have the app on an old phone that will work. All you need is wifi. You don't need cell service. Newer phones won't run the app.
Most certainly you will need a new drone battery. I would unplug the controller and turn it on and see how long it stays powered. After it's drained charge it again to see if cycling has helped.
If you are charging the controller via a USB port on your PC it could take a very long time to charge. If you are using a 1A or 2A USB power block to charge it and it is still not fully charged overnight, then the battery in the controller may also be kaput.
Reactions: WTFDproject
simhopp
