My Plus controller got caught in a loop during boot and repeated attempts to resolve it failed. It was obvious the FlightMode app was corrupted. However, it can't be reinstalled unless the ST16 is booted.
Thanks to @Haydn and @Peggy for several suggestions, I was able to find a method of getting to the Android Settings to reset the controller.
Recover ST16s for H Plus
Access the update file for the Controller
TYPHOONHPLUS_CONTROLLER_1.1.01_BUILDxxx_xxxxxx.yuneec
Change the file extenstion from yuneec to zip.
Extract the file: update.zip
Access App
TYPHOONHPLUS_APP_1.0.08_BUILDxxx_xxxxxx.yuneec
Extract the file: Yuneec-App-Release.apk
(Or use this link to download the apk file: Yuneec-App-Release.apk)
Copy Update.zip and Yuneec-App-Release.apk to a micro sd card.
Install the card in the ST16.
Turn on the ST16, wait for the Yuneec logo to time out, press and hold the center
button before the second Yuneec logo appears. Continue to hold until the splash
screen appears. Tap the screen a few times and a popup menu will come up. It has
2 options: Upgrade or Launch. Press and hold Launch and an android screen will
open. Sweep your finger down at the upper right hand corner. Select Settings.
Scroll down to Reset and select Factory Reset.
The controller will process the reset and then will reboot. When it boots back up
it will find the Update.zip file and will execute the file. Then it will reboot again
and come up to the Pad screen. Open Pad, Settings and change the security setting
for external storage to allow the files to run on the sd card.
Open file manager and access the files on the card. Select the .apk file and select install.
After it installs reboot the ST16 and it should open to the flightmode screen. Then run the
firmware updates.
Access App
firmware updates.
