C23 gimbal - help needed
Sweden
Hi.
I have not flown my H+ for month because of lots of work, but yesterday decided to take my H+ for a spin as weather was perfect for a flight.
Did a quick checklist in my head, and concluded we where ready to fly. Powered first ST16s on, waited to get enough satellites and the powered on my H+ up as normal on my lawn.
BUT to late i saw that I had forgotten to remove the C23 camera transportation support and now the gimbal sounded 'unhappy' eg. C23 beeps 2 long and one 1 repeatedly, and led blink red.
I powered off the H+ as soon as possible, maybe after 10 sec, but now i dont have a functional gimbal. Camera works on controller but the gimbal are toasted.
Does someone have a clue how to fix this or do I need to call Yuneec for repair?
PS: The squeaky sound in the background is my sunshade moving in the vind, and not my H+ :rolleyes:
I don't see the LED showing any signs of life on the camera. Are you sure the camera is powering on? You do see the video feed on the ST16?
Also, paint the gimbal lock with bright red or yellow so you don't forget it. I've also attached fluorescent ribbon which hangs down.
Hi Steve.
Yes I see video on my ST16S.
In a way, you may have been lucky. The code you hear is the Pitch (tilt) encoder error. Of all the things that can go wrong with a C23, that is just about the only one that can be easily repaired. See Attachment 26 (C23 / E90 Pitch Encoder Replacement) of ""Way To Fix Drones project".
The part you need is YUNE90109SVC (E90 Pitch Encoder) . You can contact @Yuneec Skins to see if he has any in stock. I did not see them on his website, but he has a lot of stuff that is not yet listed.
You might notice the part number is listed as an "E90" part. That's because most C23 and E90 parts are the same, and only listed under the E90 part number.
Now the bad news. It is also possible the gimbal board or other related items were damaged. If replacing the encoder does not fix the issue, the camera would best be sent for repair.
Thanks.
I will try to fix it myself. Do I need to replace 1 or 2 pitch encoders, and do you have any knowledge of a European seller.
// Martin
Thanks.
// Martin
Possibly copter.eu, although the search function in their website comes up empty for the part number. Yuneec UK or Yuneec Germany are other possible sources.
Thanks.
// Martin
You only need one. I notice in the US they are sold in pairs, but do not know why. There is only one on the camera.
I think I might have this issue with a new c23, thank goodness I found ur post. This will be my next task. My question is could this fail on a brand new c23 out of the box , I’m not to easily surprised anymore 😅
My question is could this fail on a brand new c23 out of the box .....
Absolutely. A common cause of the code is encoder magnet degradation. The degradation is mainly related to age. Prior usage seems to have little to do with it. The few cases where history was available suggested the environment also has little to do with it.
Reactions: Stephen1988
Still same issue after instal, hopefully not the ribbon 😄
Mihal05
