Camera Serveo Gear broken
That’s the stronger gear of the two. Must have been wracked pretty good for it to break like that. Is the smaller gear ok? As it broke in the middle it seems unlikely you can reverse the gear it repusition it, but might look at that. I recall it only moves 90 degrees so maybe pulling it and repositioning may help? There should be done ‘stops’ that may need repositioning too.
PerfectPlanqa
